My Sea Doo dealer pointed out that our '96 110 hp Sea Doo Challenger had previous freeze damage. Apparently the outer jacket had bulged and a slight crack as a result of the engine not being completely drained by the previous owner.
The shop said the crack had been ground down and filled. He felt that if the epoxy used to fill the crack was holding, he wouldn't recommend doing anything with the block, and if the leak was an issue or got worse, then we could then address it. Does this sound logical? This is our first jet boat experience.
Thanks.
Thanks.
