Can someone please help? I have a 1999 GTX Limited and when I hit the throttle it doesn’t go above 10 MPH. (Its bogging) I sometimes let go of the throttle and then punch it and it takes off, but idles just perfect. I was testing my ignition and noticed that when I remove the longest wire going to one of the spark plugs the engine feels the same no different than when both ignition wires are plugged in, but as soon as I plug back the long wire and remove the shorter ignition wire from the other plug the engine cuts out. I was trying to turn the engine with only one wire (the short one) and the engine comes on. I did the same thing with the other wire (the long one) and the engine will not go on. I tested both wires and noticed spark coming out of both. Can the engine be able to start and run with either wires plugged in? It only runs with the short wire in not the long. Why!! Can someone please help? Also, I put new plugs in and clear fuel filter from inside the hull not the carb filters.
