My sea doo always starts and idles perfectly. but I have an intermittant problem. It seems to "run on one cylinder" intermittantly, engine shakes, and of course slows down. Upon slowing it always idles perfectly.
The Plugs never look wet. changing plugs has no impact. Spark tested with a timing light on the wires show spark all the time, even when seeming to run on one cylinder. Compression is 135 lb on both cylinders, cold dry.
I pulled off the carb covers and held my hand over each carb while "running on one", same effect on each carb, so "choking" did not improve performance.
I checked all the fuel lines and put new clamps on just in case, checked and cleaned the filter, was fine.
When it goes, it has a top speed of over 50mph and shows no sign of lean or rich condition, the carbs seem to be in perfect tune.
Can anyone help to identify my intermittent problem? Thanks.
