WD-40 Vs. fogging Oil
  • WD-40 Vs. fogging Oil
    I was wondering if you can use WD-40 in place of expensive fogging oil to fog a 2 stroke engine? WD-40=$2.00 vs. Sea doo fogging oil= $10.00
    Are there pros and cons?
    thanks
    XTMSports, because life is short!:D
    Re: WD-40 Vs. fogging Oil
    I think you are getting bomardier lube confused with fogging oil. Fogging oil=Bobardier storage oil. WD-40=Bombardier lube. So to answer you question, no, you cannot substitute WD-40 for fogging oil. However, you can buy cheaper fogging oil from a auto/boat store. WD-40 can be used as a substitue for the bombardier lube.
      That clears things up a lot. thank you sir.
        Another thing to remember.. Fogging oil is not flammable.. WD-40 IS!!! I would hate to see what would happen when you put WD-40 into a running cyl.... EESH!
        Dan Solie -
          If your leaning over and looking into the cyc. it might be the last thing you'ld see!
            Fogging is to be done with the engine running. WD 40 would combust in the clyinders, not leaving much oil to coat the bottom end of the motor, other than that, it is harmless.
            Use fogging oil.
            I like Mercury Marine Storage Seal. I buy it at a boat store that sells Mercury products ( also SD dealerships that sell SD boats with Mercury engines in them ).
            That stuff blows away Bombardier fogging oil, much better product.
              Take a cup & spray it say 1/4" full of WD-40 and put it on a shelf somewhere for a week. When you come back a week later almost all of it will have evaporated.
              Not the type of thing you want to use for protection and long term storage of an engine.
              Devin Noel
              '03 Sea-Doo XPdi
              '98 Sea-Doo GSX
              Kwajalein, Marshall Islands (2,000+ miles from anywhere)
              devin.noel@gmail.com
