anybody ever install a aftermarket fuel filter on a seadoo??i was thinking it would save you from having to clean out the little filters in the carbs so often or would it screw up fuel flow??any recommended type? thanks
aftermarket fuel filter on 97 gtx??
Re: aftermarket fuel filter on 97 gtx??
you have a fuel filter / water seperater on that, it is up under the front of the ski. (buy where the steering is.) pull the front storage compartment out, and look up, and to the rear of your boat. this is a good filter, and there is really no reason to add another one. just be sure to keep it clean.
typically, on the doos with the grey fuel line, the fuel line is known for going bad (on the inside), and getting brown crap / goo in your carbs. i would recomend replacing all of your fuel lines with new ones. you can use regular automotive fuel line from your local auto store. good luck, and keep those filters clean. zigplease visit my link with pics of my many parts for sale
http://pg.photos.yahoo.com/ph/radracingpics/my_photos
email radracingpwc@aol.com
Yea, I installed an inline filter on mine only to find it starved for fuel at top end. Not at first...it took about 20 seconds of full throttle, then it started hesitating. Not a good thing. Leaning out wide open will ultimately lead to seizure. I stopped mine immediately 'cause that was the end of the season last year. Now I'm going to change out all of the lines with the auto type.
I cleaned out the gunk in the carb filters before all of this....that's why I put the filter there.
bottom line is...I don't know if the filter actually restricted the fuel flow, OR the siphoning action from the pump itself. So, I'm removing the aftermarket filter when I install the new lines.
Anyone currently using an inline filter?
There is nothing wrong with adding a free flowing aftermarket fuel filter inline on a watercraft. Just make sure it has low resistance and is suitable for the application. Do not use a paper filter.Bill O'Neal <br>
