Re: Jetting a 951 1998 GTXL
1997.5 carb mounts with accellerator pump in the front, 1998 plus models, the accellerator pump end of the carbs is at the rear of the carbs, away from the mag housing/ front of the boat.
You also do not need to connect any hoses to the little fittings on the diaphram covers that came with the 1997.5 GSXL..
