Re: help 96 XP
One last thing, when I cleaned the carbs last year and discovered that it was a lean seizure. I didn't buy any rebuilding kits for the carbs is this something I should do ? Gaskets all looked good and motor started and ran better then you would expect with 45lbs of compression in one cylinder.
