Factory Pipe Spec 1
  • Factory Pipe Spec 1
    Hello all,
    Let me just first say that you guys have an excellent website and a vast array of knowledge with all of your members. I have a modified 95 Seadoo Xp which i purchased a used rebuilt motor last fall with some mods done to ie bigger crank bigger pistons factory pipe spec 1 w/ecwi and ocean pro flame arrestors w/aftermarket waterbox. I'm wondering if anyone knows of any online retailers of factory pipe where I can get the necessary gaskets if there are any as I have installed the motor into the hull but have not hooked up the exhaust or the pump(letting the dealer do it next week) as I am not to famaliar with this system. Thanks any and all info will be greatly appreciated!!!:)
    Also all the hoses, etc I might need to complete the installation, thanks
    Re: Factory Pipe Spec 1
    http://www.factorypipe.com/index.html
      Thanks Xp canada,
      I checked out the site but I didn't find just the gaskets or a way to order them. oh well mabye the dealer will know what I will need thank you for your quick response!!!
        The Spec1 series uses an oem headpipe gasket. It's the Spec2 that uses a FPP oversized gasket.
        Bill O'Neal <br>
          Thanks Bill,
          I wish we had a shop like yours here in upstate Ny!!! Any idea on the hoses or anything else I might need to finish installation? Thanks
          Also this engine came out of a 95 hx do the splines inside the pto match those of an xp driveshaft for that year? I have to find my driveshaft might have lost it when I moved a couple of months ago
            disregard.
            Bill O'Neal <br>
              Bill,
              So what you are sying is in theory if I want to use this motor I have to switch out the pto correct? Cause I think the Hx driveshaft is a 2 piece and my xp came with just the one piece. So if I want to use this engine in my 95 XP I would have to switch the pto to make my stock driveshaft compatible?
                Not if you have a 1995HX motor. If you have a 1995 HX motor, the driveshaft for a 1995 XP will work with that splined PTO.
                If you have a 1996-7 HX motor, the PTO is the one with the coupler on it, and it will not work with an XP driveshaft..
                I'm sorry, I thought you had an HX.
                Bill O'Neal <br>
                  The one I have Bill just has a grease fitting on it there isn't any rubber seal around it like the stock motor had on the end of the pto. i'm about 80% sure that it was a 95 HX
                    So, someone took the rubber seal off of it. All splined pto's use a rubber boot on them.
                    Bill O'Neal <br>
                      Whew,
                      Just wanted to make sure that I had the right one. I ordered a new one is a zip tie ok to secure it to the pto? I don't have those special pliers for the seadoo clamps.
                      • #12
                        Yes, we all use zip ties.
                        BTW, even a new pto does not come with the rubber boot. You order it sepretely.
                        Bill O'Neal <br>
                        • #13
                          Thanks Bill for all your help, Build a shop in upstate Ny will ya? thanks again:)
                          • #14
                            Yeah right !
                            Move to sunny So Cal like millions of others choose to do.
                            Bill O'Neal <br>
