Where can I get cylinder-to-crancase (qty 8 - M8x70mm) and head (qty 9 - M8x55mm) bolts for a 587? Called local Sea Doo dealer parts dep't and was quoted over $8.00 a bolt!
White 587 engine bolts
Re: White 587 engine bolts
There would be a $50 charge if you are missing most of the bolts. If this is a core, we only accept OEM bolts - we cannot make an engine with local store bolts.SBT Tech Support is here to help with your problems.
