Just put a new top end in my ski. .02 over
other then that the ski is all factory, just like seadoo made it.
Ran the break in like SBT says to.
On my third tank of gas I opened it up.
The motor ran great for 30 sec.
Then if killed like I pulled the lanyard.
I re-started it; it ran poorly so I got towed in.
At the landing I put it on the trailer and ran it again. I noticed a little water coming out of the exhaust gasket falling on my carbs.
I pulled plugs, turned the motor over a few times to blow out any possible water.
Then torked the bolts and it fired right up. It seamed to run fine.
Back in the water it will not run full throttle.
It kills the and then it is hard to start.
If I let it sit for a bit, say an hour it starts back up and runs fine.
Then at full throttle it kills again and runs rough.
Help
Help
