The last time I took my seadoo out I noticed that the vts wasn't working (I just want to add this in, because it could have something to do with it) I got off the seadoo, and took the lanyard. I gave it to a friend he got on the seadoo put the key in and it didn't beep. So it wouldn't start or anything. Not matter what we did we couldn't get the seadoo to beep so we could start it.
When I took it home, I took a screw driver to the solenoid and it turned over just fine.
I've checked all the fuses on the mpem board and they were all good, I checked the fuse in the solenoid box...and it wasn't good so I replaced it....still no beeps and it wouldn't start.
I checked the VTS box since it didn't work the last time it ran, and there was water in this box, so right now I'm letting it dry out....although I didni't see any fuses in the box...but maybe there is.
The battery is good too, so I'm wondering if the posts on the DESS is out, I think I can check that out if I use a ohm meter, so I'm buying one tonight to see about it. I'm trying to fix this myself so I don't have to spend a arm and a leg to get it fixed, although I will here in two weeks if I can't get it going by then.
If anybody has any suggestions for me, please don't hesitate to let me know.
Thanks!!
Thanks!!
