Unit is blowing 5 amp fuse. It is on its 3rd MPEM. Unit will run 10 minutes on a new MPEM and pop the fuse. After that it will pop everytime the lanyard is plugged in. All connections in electrical box are good. Everything checks out okay with the stator. This is getting expensive so if anyone has any ideas it would be appreciated.
95 Seadoo XP (720) blowing 5 amp fuse
Re: 95 Seadoo XP (720) blowing 5 amp fuse
if you have replaced that many mpems you missed somthing have you tryed disconecting everything with a plug , then reconnect one at a time ?
if it happins only after running i would go into the stater look for burnt marks or a short there { might only ground out after it get hot }PRIDE IN SERVICE<br /> <img src="http://www.sbtontheweb.com/images/forposts/4609/1.jpg" alt=" - " />
