I'm new here, and this is my first post. I have a 92 sp with a 580 motor, never seen salt. It's problem: it cuts out, that is, the revs drop drastically, when it's at WOT. It acelerates smoothly until WOT, and then drops waaaay down, but does not die. It'll run fine at a hair below WOT. The carb's been rebuilt, new jets, diaphragm, etc. Coil wires replaced. The tech says the coils show proper resistance, and the overheat switch has been bypassed for testing purposes. Compression is even at 170psi.
Any suggestions would be greatfully appreciated and thank you in advance.....
And its Memorial Day weekend, and I got no ski...{sniff}
