im going to breakin in my ski the weekend but im not sure what gas/oil mix i should run. i heard so many different procedures and i dont know what to run and how to break it in
gas oil mix during break in
Re: gas oil mix during break in
EngineWith Bombardier-Rotax® watercraft engines, a break-in period is required before operating the engine at full throttle. Engine manufacturer recommendation is about 10 operating hours. During this period, maximum throttle should not exceed 3/4, however, brief acceleration and speed variations contribute to a good break-in. Continued wide open throttle accelerations, prolonged cruising speeds and overloading the engine are detrimental during the break-in period. To assure additional protection during the initial engine break-in, BOMBARDIER ROTAX INJECTION OIL should be added in the fuel tank for the first full fuel tank filling only.SPX/GSX/GTX/XP ModelsTo assure additional protection during the initial engine break-in, BOMBARDIER ROTAX FORMULA XP-S synthetic injection oil should be added to the first full fuel tank filling only.To add injection oil in the fuel tank, proceed as follows: Fill fuel tank with approximately 15 liters (4 gal) of gasoline; then, add the required quantity of injection oil in the fuel tank. Fill up fuel tank with gasoline. Do not overfill. NOTE: It is important to proceed in this order to allow a proper mixing of the oil in the gasoline.straight from the manual add 24 oz to the gas tank
