all i did was to pinch off the oil line to the pump....left all hoses hooked up...also unhook cable to oil lever....just pinched the one....i've run to full tanks of gas thru it and no problems..........but i did have one problem...this past weekend took ski out ran great........when i was beached...hadn't been running for over 10 minutes....all of a sudden the buzzer started buzzing.....
i did put new plugs in and gap to spec......old plug had a larger gap....could this have cause it or is the sensor going bad.......i did ride it back to the boat ramp with no problem ........it did start to buzz again....it even buzz when i removed the lanyard............
