I got an amazing deal on a SPX 650 this is my first seadoo and it ran great the first day but it began to run carppy halfway through the second ride. It starts fine and idles good, but when i give it throttle it goes then begins to bogg and then goes and boggs again repeatedly???? anyone have a suggestion??????
Won't run properly
Re: Won't run properly
inside the carb you have to open them up and check them id say you may be having problems because they are clogged and not getting fuel to the carbs when were they last rebuilt? or you may want to while you are at it check the high and low speed screw settings. go to Mikuni.com and opent he exploded view of the carbs and it shows you where what is on the carb
If you knew,then you'd know!
