I'm wondering if a 800cc motor will bolt right into my 95 XP 720. What would need to be done with the plate, mounts, driveshaft...?
will a 800 motor fit in the 720
Re: will a 800 motor fit in the 720
a screw came lose and dropped in my carb while i was riding. i got the screw out, it was chewed up a bit. With the plugs out it would crank but now it wont crank at all, with the plugs in or out. when it was cranking i think i heard he flywheel aganist the starter. any suggestions on what this screw messed up. i think i may have a prob with my flywheel.
Jack up the gas cap and put a 1996 hull under it :)
No seriously, if you took the time and effort to install a pad to accept an 787 front motor mount, you could do it. But it is alot of effort to do.Bill O'Neal <br>
A screw through the carb can usually only hurt the rotary valve and the tops of the pistons and head. Sometimes if caught just right by the crankshaft, it can poke a hole in the cases or leave a crack in them.Bill O'Neal <br>
Originally posted by Bill O'Neal2Jack up the gas cap and put a 1996 hull under it :)
I took off the cover and found where it was stuck(motor wasnt spinning at all) It spins freely with out the vavle on there. I'm gonna get a new valve for it but does any one know where i can buy the valve online, theres no dealers near me. Is timing it hard to do, i looked at the tech article, seemed easy, i also brought the timing wheel to install it.
We have the valves for $35, but I'd make **** sure your brass gear wasn't damaged too.SBT Tech Support is here to help with your problems.
I highly doubt the brass gear is not damaged.
If it wern't, the RV would spin no matter what.Bill O'Neal, owner of Watercraft Magic in Glendora California, www.watercraftmagic.com
