Ottawa Ontario Shops
  • Ottawa Ontario Shops
    I just had a shop install Proks and rejet my 2000 XP, but they will not tune it. I was wondering if anyone in the Ottawa area knows of a shop that will tune a SeaDoo with small mods properly. I don't really feel too confident doing it myself.
    Thanks for the help!
    Re: Ottawa Ontario Shops
    You're better off finding someone local to help you do it yourself. No shop can tune your carbs for you - it must be done on the water. A shop can only give you a starting point for the adjustment needles. We do have article here on tuning the carbs - it's not too hard, and something you are going to NEED to know if you have started moding your engine.
      SBT, I have heard of quite a few shops doing on water tuning. I believe all of them were independent non dealer shops, however. I actually had one do my waveblaster a few years back when I had a Buckshot 46 I couldn't get to work right. Turned out that the welch plug(?) was leaking fuel and after they repaired that they could dial it in.
        Yeah, if you can find a shop that actually takes it tot he water (almost unheard of in most areas) that'll work...but you still won't know how to do it :)
