I have a 1993 GTX. It ran fine last year (except needing some carb work to replace the needle valve) up until I put it in the shed for winter. I kept heat in there over winter to avoid freezing of the exhaust.
I charged the battery and when I tried to start the starter turns and grinds but the motor does not sound like its turning over. I plan to take out the plugs to night and check for compression and check spark.
I have no idea how it would have locked up over the winter when it was turning over fine when I put it away. I suppose if water got from the exhaust into the engine (don't know how since not tipped on its side) it could have led to rust buildup that is locking up the cylinders? I did not spray any oil in the engine so I suppose rust could have resulted from condensation over the winter? Did not have this problem in prior years though.
How can I manually try to rotate the engine to see if it is locked up or to see if I can break it free? I will take the intake cover on the pump off and see if I can rotate the shaft there. Don't know if there is a way to access inside the engine compartment though to rotate turn the engine over manually.
Any help is appreciated.
:^D
:^D
