97 gtx 5a fuse blowing
  • 97 gtx 5a fuse blowing
    every time battery is connected the 5a fuse blows. all components are dry. i unpluged the black/yellow wire just below the 5a fuse at a bundle plug just before it goes into the steering column. it is possible this is the start/stop button, or kill switch, or what ever the third wire goes to. should i start by replacing the start stop. or is there something else i should do.. thanks
    Re: 97 gtx 5a fuse blowing
    Please use search, this has been answered many times.
      get an ohm meter or circuit tester and start looking at your wires for a short somewhere most likely in your stator somewhere
        It will not be a start stop switch or a tether problem.
        It will probably be the mpem that needs replacing.
          i second the mpem..
          the 5amp is the main fuse and it wont hurt to swap with a good one to see if the problem goes away..
          get any 787 mpem-gray box and try it.. you of course need the programmed key as well
            If you swap MPEM's with a known to be good MPEM out of another 1997 GTX, and it still blows the fuse, remove the magneto cover and fix whatever is broken in there.
