I was wondering if anyone has used just a simple 4x8 utility trailer for their ski? I have a flat bed 4x8 and looking at purchasing a ski without a trailer. Can it be done without altering the trailer?
Using utility trailer for ski?
Re: Using utility trailer for ski?
Well, you could use it in a pinch if you had to transport it - but no, you can't use it to launch with unless your vehicle is a submarine. You'll also destroy the hull after a while, from the abusive contact.SBT Tech Support is here to help with your problems.
Here are 2 pictures of how someone did it.
Unfortunately this trailer has 2 problems
1. It is not galvanized and was used in salt water.
2. The plywood deck sitting on top of the steel rails created the perfect hiding place for moisture.
You can't easily see what's happening under that plywood but on a quite night you can almost hear it rusting away.*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~ *~*
Just because you are paranoid, it doesn't mean people aren't talking about you
