Just installed an SBT motor, it'll crank over just fine, but doesnt start. I'm pretty sure the overall reason is obvious, it's not getting fuel. I emptied the inline filter and when i crank the motor over, no fuel is being drawn into it, so it's obviously not ever reaching the motor. The carbs were fine prior to the new motor, the only thing i changed with the carbs were installing new carb filters. Maybe it's possible one of the gaskets or diaphrams inside the carb was moved or torn when installed? All the fuel lines in the boat are new.
any thoughts? Should i pull the carbs apart again? The carbs were rebuilt about 40motor hrs ago, but that was also 2 years, timewise.
Thanks!
bob
Thanks!
bob
