When I get home this evening, I am planning to start putting the engine back together again. I want to do this right so I have a few questions:
1. When I took the engine apart, I noticed that there was a clear silcone applied to the starter as well as to the flywheel cover. Is this necessary or was it just extra protection? Is there any other places that this should be used on the engine?
2. I know that loctite ghoes around the the threads of the bolst. How do you apply it to nuts?
3. Where do I put the loctite for the flywheel?
4. I notice that loctite comes in several strengths. the blue is light wweight and used for most of the rebuild. What do I use for the flywheel, is it the red?
5. What is the green stuff used for ?
Like I said, just want to do it right as well as a good learning expierence for me.
thanks
thanks
