Just finished pulling carbs on my 96 GSX and rebuilding using the SBT kit. Went very smoothly, particularly after watching the video online (thanks guys). I'm installing an SBT block off kit as well (10 years and 200 hours on the oil pump making me nervous). No problems here except there is nothing in the kit to block the large oil line that travels from the tank to the pump??? Can I just clip the line near the tank and plug it with a bolt and a zip tie?
Also, I've left the other 2 (gravity fed) oil lines untouched and I'm assuming the low oil sensor in the tank will continue to work thus warning me when the crank case oil needs attention..... ( I visually inspect before each ride anyway, so it's merely a back -up)
Thanks in advance!
-Drew
Thanks in advance!
-Drew
