My 96 XP which has been a very reliable and fast ski for quite a number of years quit running on me this past Sunday. I was a little worried that a seizure had occurred even though I was not hammering it when it when wah wah wah and I tried to feather the gas to keep it running when I noticed it was trying to die. Anyway, after it came to a stop in the water I hit the start button and it went "conk" as the starter tried to crank the engine but, it just went "conk" that one time and then while I was still holding the button it let out one long beep and then it would not chirp when I removed the replaced the lanyard and wihout any chirp chirp it would not try to crank anymore. When I towed it to the shore I took the plugs out and could turn the pto with my hands without much trouble. After disconnecting the battery and reconnecting it several times it did start chirping again. I then took my ski over to a friend's nearby house and actually got it to start but, it would not rev up correctly. It's as if the rev limiter was holding it down and it did not want to rev freely and it would not rev over around 4,000 rpm while it was on the trailer and it kept wanting to die. Anyway, I brought it home and today I replaced the front gray box with a friend's stock front gray box and it did chirp and when I hit the start button it went "conk" one more time and that was it and then it did not "chirp chirp" for me anymore until I replaced the coil box and then it "chirp chirped" for me once more and one "conk" when I hit the start button. So I've changed out both electrical boxes and it's still doing the same thing and it's not wanting to go "chirp chirp" for me unless I disconnect the battery and reconnect it a few times. So I'm left with fewer possible things that could be causing this problem. My first guess is the DESS post itself and secondly the starter and thirdly the pickup or stator? Has anyone here "Bill O" ;) seen this problem before?
Ben in TN
Ben in TN
