Carb low and high idle screws
  • Carb low and high idle screws
    I know this sounds dumb but i have to ask Which screws are which as far as setting the high and low idle. I re built the carbs and need to tune them 1994 xp.
    The big needle I took out when rebuilding which is it and where is the other located ?
    Re: Carb low and high idle screws
    The high needles go in the holes more towards the top of the carbs. The lows are the opposite side, more towards the bottom and they are the ones with the t-handles.
      Thanks I finally found in the tech articles thanks again.
