Does anyone know if a 94 XP has the same size sending unit as a 1998 GSX-L? or if any model jet ski has the same size?
does anyone know if
Re: does anyone know if
I have another question...on my left gage it shows the gas and the trim..well neither the trim part works on the gage nor the trim button or the gas but the red light works...do u think the trim is bad too.SeaDoo GSX Limted 1998
Seadoo XP 1996
Seadoo XP 1994 Twin Carb
Why do you need to know if another part will fit? Get the right part and be done with it! Any other similar model's sender will be in the same price range anyway.SBT Tech Support is here to help with your problems.
In 1998 SD went to a bigger motor with bigger fittings for the fuel lines on the baffel. The only baffel that could work would be from a 1898 or later GSXL or Possibly a 1998 or later XPL. You would have to measure the length of the baffel to see if it would be too long or too short.Bill O'Neal <br>
