mity vac instead of pop off pressure tester?
  • mity vac instead of pop off pressure tester?
    couldnt find one for sale anywhere in town, but plenty of places sell mity vacs. Since the mity vac can be used to pressure test the pump, can't it be used for the carbs as well? and...if i reuse the same spring, should the pop off pressure be okay, as long as the n&S are in good shape?
    thanks!
    Re: mity vac instead of pop off pressure tester?
    yes to both questions
      Go to Sears, they sell it.
        standard might-vac pumps only pump up to 12psi. Read the package before you buy one.
        "I'm doing the best that I can according to my current awareness!"
          hmm, the only mity vacs, their guages only read in vacuum. If i set it up for the pressure side, the guage won't register anything. Will a vacuum test provide the same results as a pressure test? The guage reads up to 1 atmosphere (14.7psi or 30in.hg)
          thanks!
          Bob
            no vacume wont work , the mighty vac i have does both and goes to 30psi
