I need help identifying my carbs. I recently rebuild a 96 XP engine and I am having problems with top end. The carbs were rebuilt replacements installed by a local shop last year in an attempt to get the ski running for the previous owner. I tore into the carbs this evening and from my manual it is supposed to have 140 main jets, these carbs have 135s. I want to make sure the carbs are even the right ones for this engine. I can't find any number except for a 252 and a staggered 153 on the flang on the diaphram side of the carbs. The jet sizes don't match any of the stock settings for any 96 sea doos so I am at a loss.
I measured the diameter of the carb bore on the manifold side and it is 40mm not 38 or 44 or 46.
Am I going to get luck and just need to put in the correct jets or am I going to have to change out my carbs.
Any Help would be great.
Woefully Jetted in MO
Tony
Tony
