I've read about some similar problems on your forum but, mine seam slightly different. Here's my problem/simptoms:
Starter will not turn over, no noises, no clicks, nothing.
Here's what I know so far:
Thanks,
David
- Single tone when the lanyard is attached with normal readout on the display
- New battery, tested voltage, 13 volts
- No voltage at (red cable) (starter side) of the solenoid in the rear electric box when depressing starter button
- Tested Good, 5 fuses, 2 in the rear electric box, 3 in the front electric box
- I hear a switch or relay in the front electric box closing when I depress the starter button. (But, I do not hear this every time I depress the starter button) (Is this normal?)
- I can start the engine by attached the lanyard and shunting the two red cable posts on the solenoid. (not the smartest thing to do, but yes I did try it and it worked)
Thanks,
David
