my 92 seadoo sp will idle and thats about it,when you open it up,its like shutting a key off and on about evry 2 seconds---help
92 seadoo sp no full throttle
Re: 92 seadoo sp no full throttle
bill; the fuel valve was clear and clean,could there be something in the tank only letting a certain amount of fuel pass,also is there a check valve in the tank which could be bad. still idles only,falls on its face when you give it throttle
what kind of shape are your carbs in? Try taking the fuel inlet line off the carb and running a line out of a bottle to the inlet fitting and then running it and see if it does any better if so you need to trace down the problem with your fuel lines if no improvement then maybe you need to give some attention to you carbs.
