I have a seadoo 4-tec supercharger and after I am riding a little while the check engine comes on the display.All fluids are full and there are no codes coming up on the display.If I turn it off and pull the tether out it resets.I am confused with check engine but no codes.please help.
check engine
Re: check engine
I am having the same problem with a 2004 GTX 4-Tec Limited Supercharged. It has less than 100 hrs and is still under warranty. Took it to the dealer and he said it had too much oil in crankcase. (The dealer changed the oil at 10 hours and I have never added any) I don't know if there is a code for oil level. The dealer removed some oil and test drove it. All OK. I rode it for a couple of days without any problem. It has since triggered the "Check Engine" light three time in approximately 10 hours of operation.
The ski runs OK and there is no indication of heat problem. Don't know what to do now. Any suggestions?
