went to start ski to flush and the clock and everything else was set to 12:00 and 0.what could have happen thanks in advance.
gtx rfi time reset
Re: gtx rfi time reset
It reset itself to default for whatever reason. You need to press the mode button menu to reset the functions like the clock. Once you see the flashing numbers, press the set button repeately until you get the number you want. Then press the mode again and set the hour, so on and so forth until everything is set the way you want it to be.Bill O'Neal <br>
