2002 GTX 4TEC: The buzzer is very faint, sometimes it will work properly, but mostly is is very very faint. Should I replace the buzzer? Is this a common problem and is replacing the buzzer the proper fix?? Thanks
Faint "Beep-Beep" on 4TEC
Re: Faint "Beep-Beep" on 4TEC
if you have a bad beeper you should replace it . its not to hard of a job , easy way to tell is to plug in a new one .it is very commin for them to go bad on all skis .PRIDE IN SERVICE<br /> <img src="http://www.sbtontheweb.com/images/forposts/4609/1.jpg" alt=" - " />
