Gear lube at end of driveshaft?
  • Gear lube at end of driveshaft?
    I have a 95 speedster and i wanted to know if there is supposed to be gear lube at the end of the drive shaft where the little black cone is?
    Re: Gear lube at end of driveshaft?
    there should be jet pump oil(synthetic) in the cone and you should change it at least once a year
      mobil 1 gear oil 90 w
      SHOOTER
