Re: 95 XP Looses Power
Thats happened to me twice on my XP. I keep a watch out for them now when I go through a NWZ.
I also have a 95 and mine use to bog too. Ended up being that water was leaking in from the hose that goes from the front head to the exhaust. All I had to do was tighten the clamp and it was good. It would run for like 20-30 mins then bog out and stall. If your getting water in your Hull that could be the problem. You said you installed a pump, so I guess you are getting water in the hull. Might be something to check although I am no expert on PWCs.
