I am replacing a bent drive shaft on a 99 gsx rfi. I have it apart and will order a new shaft today. Is there anything else I should check and or replace while I have it apart? The pump clearances with the impellor looks good and the it spins without and odd noises.
Replacing bent drive shaft
Re: Replacing bent drive shaft
DO YOU KNOW IF THE SHAFT IS SUPPOSE TO VIBRATE A LITTLE OUT OF WATER. I FOUND A ROPE LODGE INSIDE THE SHAFT.Originally posted by JohnnylawI am replacing a bent drive shaft on a 99 gsx rfi. I have it apart and will order a new shaft today. Is there anything else I should check and or replace while I have it apart? The pump clearances with the impellor looks good and the it spins without and odd noises.
I do not know what "viberate a little" means to you. If you can feel it shaking the ski, it is too much viberation.
The true home test of a driveshaft is to roll it across something flat and see if it wobbles.Bill O'Neal <br>
On Mine you could visibly see the wobble. took it out and rolled it it was definately bent. You could not feel it while riding in the water. But you would suck air through the carbon seal whenever you took off. I can't imagine any wobble is good. SBT has the driveshaft fot $137.00
