I am in the process of putting a new jet pump on my 1990 Seadoo. Assembled it with the thrust washer and bearing. Put on the nosecone and added the Seadoo oil. Spun it by hand for a while and left it on the bench ovenight to check for leaks. Now I notice a little play in the impeller shaft assembly. Maybe 1/16" or less. Is this normal? How much play should it have?
Indalake
Indalake
