I am going to install a primer on my 97XP. I know that it has a accelerator pump that should prime the carbs but I don't seem to get a squirt of gas coming out of the accelerator pump when I squeeze the throttle. I removed the fuel line on the outlet port to verify if any gas is squirted and nothing comes out.
What I am planning on doing is using the hole where the choke knob is currently. I just want to make sure that it would work with that much primer line (basically would have to go from the handle bar down to the front of the ski and then back to the carbs. I like the idea of not having to raise the hood to pump the primer.
If somebody has pictures of the way that they installed the primer on a 97XP that would be helpful.
