my 95 xp seems to be reving very high. rpm gauge doesnt work so i dont know for sure. how would i lower the rpms just a little. i dont wanna play with the wrong screw. also does it make a difference that it is out of the water? i would put it in the water but i dont want to get left in the middle of a lake again
95 xp with very high rpms
Re: 95 xp with very high rpms
i took it in the water, it ran good but i still think its a little high. when at idle the ski will move foward like it has cruise control. bill could you tell me the screw is on the carb, is it the bigger screw? thanks
There is only one idle screw with a tee handle or screw pointing up on a 45 degree angle towards the front of the ski next to where the throttle cable attaches to the carbureators.
Maybe you need to adjust some slack into the throttle cable?Bill O'Neal <br>
