had a 93 xp , rebuilt carbs , ran great, turned it on its side and did 5 layers of fiberlgas . turned over and would not start. drained gas tank ,cleaned lines, took carbs apart again to no avail.now i did have weak spark, bypassed plug boots and then have no spark .I understand now about the resistor in plug cap interfering with mpem. I think in one of the other posts that you take a white wire off of mpem/limiter circuit and it should run but not turn off. I was the on that put the 657 in there 3 years ago. I know what im doing on skis. However they don t make it simple to diagnose elec problems.Im going to get plug caps today and ill see what happens.by the way the 15 amp fuse was blown , I think i shorted some wires from the motor to elec box.I put new fuse and nothing.Any suggestions on how to isolate this problem?
no spark
