I'm haveing the toughest time removing the factory stickers on my 96 seadoo XP. I bought a can of label sticker remover but it only seems to work on the glue once you peel some of the sticker off. which is the problem I'm haveing as soon as I get a good peice of the sticker up and start to pull it off it breaks and the stuff I bought won't penitrate the sticker itself. What can I use to get them off easyier without haveing to use a razor blade or even hurting the ski's gel coat or paint? :emoticont
Dose Anyone know the best way to remove the factory stickers
Re: Dose Anyone know the best way to remove the factory stickers
I use a heat gun.That worked real well for getting the stickers off. Once the stickers are off use the remover to get the leftover glue off the hull. Just be carefull if you use a heat gun not to get the hull too hot ,it will bubble the paint . :emoticonb
Schultztec
I use a high quality 2 inch clear box tape, a heat gun and a flat razor blade.
Clean the decals to remove any grease or wax first, then, the tape will stick to the decal better and keep it from "breaking away". The heat gun will soften the adhesive and the razor gets under the decal to get you started.
This also works great when changing the registration decals every year.
I use a decal wheel (3M Decal Wheel) that you can get at most home improvement stores.. Just put it on the end of your drill and the stickers come right off (in 1000's of peices). You can get different size wheels if you have a lot of stickers or a large one to do.Dan Solie -
AV gas bubbles those suckers right up.
That and Havasu 116* heat. I found out unwillingly :(Being ignorant, is not so much ashame as being unwilling to learn. Benjamin Franklin
Really... Havasu heat and race gas huh? Well, I guess I will be repainting my boat after world finals afterall then lol.Dan Solie -
