Another GSX Problem
  • Another GSX Problem
    Ok i just posted about the rpm issue,also would like to say that the Vts is screwed up so i trimmed it all the way up and it was having problems getting up
    on the water,like it was slipping but i did have 6 inches of water in the bottom to find out later.should the vts be trimmed down when taking off then trim it up after you get going?
    Re: Another GSX Problem
    It should not matter unless you weigh 400 lbs. 6" of water should be removed. You will pop up on a plane faster with the trim down. It sounds like you may have some power problems
