HELP... I have a 96 XP that wont go much past 10 mph. It will speed up if the turn the gas on/off/on/off, as if Im leaning it out...I can maintain 25 mph or so doing that. The large sea-doo dealer here has no clue...says thay looked at cards, removed exhaust pipe to check for blockage and so on.. Any ideas... they want to take my other 96 xp and just start swapping parts till the problem goes away...thats costly. They even changed the implellet cause it was beat a little...I simply need some ideas! PLEASE. Compression is good, uptop and below.
It starts okay and runs "ok", doesnt sound right, but plugs look fair, little wet, but not bad.
