I've searched the forum and found several applicable threads but thought I would try and get it one shot here.
My 96 XP ran well yesterday. After running, it sat for about 1 hour. Went to start it again, it fired up immediately but then just cut out. After trying to crank it again, it wouldn't fire up. Several more attempts...nothing. I pulled the plugs and noticed they were wet..with fuel although could be some oil too. I dried the plugs..tried again. It fired instantly briefly but than died and backfired out the exhaust.
1.) What do you all recommend to get it running again?
2.) Is the root cause of the problem likely to be worn seats / needles in the carb?
Hope you can assist, Tom.
