I have a 95 XP with a 720cc engine and have rebuilt both carbs which included replacing the needles and seats (per your recommendation). I do not have a pop-off pressure guage, so I took the carbs to a shop to be tested. The shop set everything up and said I should be good to go. Not So!
My original problem was and still is that the carb/s allow fuel to flow into the case even after the engine is shut off. To double check, I took the carbs off of my sister's 95 XP which runs fine. Even with the good carbs installed, the same thing happens.
I have not checked the return line to ensure that it is not clogged. If the return line is clogged, could it cause the gas that should be going back to the fuel tank to trickle back into the case and cause the engine to flood???
If it's not a glogged return line, what would you suggest?
