First it sank, then an hour later I had it running again and it seem to be ok. Later a friend took it out and after I went and pulled him in, he reported that it would run a little while and stop, then run a little while again and stop until finally he killed the battery trying to get it restarted. I feared the worst but hoped it was only a battery.
The next day I put another battery in and rode it very slowly(30mph) to the ramp(~1 mile). When we go in sight of the ramp, it started acting funny again but I was able to idle the rest of the way. The rear cylinder was reading low when I tested it last night. Now I have pulled the head and even the front cylinder has some scoring but the rear has some pretty deep scoring on it.
At first I was blaming myself for it sinking because it sank due to an exhaust hose popping off. a hose that I had removed while installing the sponsons. But, while trying to start it after the sinkage and even the next day it shot water about 3 ft out the exhaust and the exhaust isn't even pointed out the back. And When I was rinsing the salt water out, my helper mentioned that there was a steady stream of water coming out where I had never seen it come out before. This water was very hot even after what was coming out of normal pisser had cooled. The hole is under the VTS boot at about the 3 o'clock position. I now think that this was letting water in where it shouldn't(Not in the hull but in the exhaust). It may have shot out like that and blown the hose off.
So does anyone know what this hole is? Is it normal and I simply never noticed it?
When he described it starting and only running for a short time, I guess this was a series of seizures. If this is true, what are the odds that the crank or con' rod bearings got enough crap in them to be a problem? It feels smooth when turning over by hand and it didn't make any different noises when running. I did notice that the pump rattle more than usual, lower idle I guess. The cylinders are coming off later this week, how do I check the lower end? Finally, I thought that the PITA exhaust bolt was a socket-head, mine looks like a 15mm nut on a stud. If a swivel socket will not fit then it looks like the carbs will have to come off, any advice?
Thanks for reading this far,
