Put new plugs in the boat, it won't idle. In order for it to start, you have to give it atleast 1/4 throttle. Fuel issue? Pump and drive shaft are straight and ok. Brand new wear ring. Engine was full of water when I received it, but I have since got that out. Oil is still a little milky. Suggestions?
GTX 4-TEC help
Re: GTX 4-TEC help
At least one of them, yes. If you got that much water in your enging, obviously something very bad happened. Most likely you have more issue - you need to go over everything - but don't expect it to be like a 2 stroke - just fire it up and run it. Doesn't happen with 4's.SBT Tech Support is here to help with your problems.
