717/720 needle bearing count
  • 717/720 needle bearing count
    A search turned up 34 per piston, I'm just looking for clarification and then I'l go away!
    Thanks,
    Rob
    Re: 717/720 needle bearing count
    1995 shop manual says 34 rollers per...
      And a 95 Xp I do have...thanks for the concurrance.....
        IS there a caged version for the 717/720 (stock rod)
          Not for OEM, or that fit OEM rods. Only aftermarket rods take the caged bearings.
            OEM rods can use caged bearings { they dont come stock in a seadoo } but they work fine , ive been using them for yrs . i wouldnt use cageless unless i have no choice .
              Which brand(s), Chris, because ours are a smaller diameter?
                i use WSM bearings unless i get one of your cranks then i use your bearings since they come with the shaft .
                  My new Pistons are WSM...where can I get a set of these bearings?
                    9.60 each shiped if ya want them just let me know .
                      Oooh..IM sent for clarification and payment option..
