i have a 96 xp with a fac pipe spec 2 and i was wondering can i bypass the waterbox rave valve and go straight to the sprayer fitting on the pipe instead of going into the valve then out the valve to the sprayer. kinda like direct spray . will it help or hurt:emoticont :emoticont :emoticonn :emoticonn
xp factory pipe spec 2 water injection
Re: xp factory pipe spec 2 water injection
A Spec2 uses ECWI to inject water into the head pipe. The kit calls for the removal of the oem water regulator on the muffler and to install a brass fitting into that fitting, then you can jet the fitting later for more performance. The Water regulators that came on 1995-1996 XP's did not last long, especially when used in saltwater. To get rid of that whole problem, we used a 140 main jet in the fitting in the waterbox in place of the water regulator and we tapped the midpipe brass fitting and installed a 95 main jet in that fitting.
We then were able to gain a couple hundered rpm over the water regulator setup. The important thing to remember is to keep the jets cleaned on a regular basis. Salt and exhaust residue clogged them up.Last edited by Bill O'Neal2; 08-29-2005, 05:58 PM.Bill O'Neal <br>
Bill will this work on a 96 GTX with a stock exhaust because i dont know if the water regulator is working right on my ski.Originally posted by Bill O'Neal2To get rid of that whole problem, we used a 140 main jet in the fitting in the waterbox in place of the water regulator and we tapped the midpipe brass fitting and installed a 95 main jet in that fitting.Last edited by Dave96GTX; 08-30-2005, 09:55 AM.
